I thought to show you some steps you could take while using the restyle function of AI Shots.
This is a little rocket I once made using SketchUp (don’t shoot me). It has terrible translucent materials assigned in KS which I had done also ages ago. But it will be the base of the experiment.
This is the rocket after I pushed KS into imagining this rocket on a rocky planet. As you see it gives a nice cartoony look and the rocks which are actually modelled keep in place but got way more lively. The background however is created with the prompt.
This is the same image but upscaled 4x (to 4096x4096) using GigaPixel Pro AI. Often this will even result in a higher quality than the original by it’s pretty clever functions.
GigaPixel Pro AI has also another trick in you can use, it can actually add detail to a picture. You will basically give a prompt again and it will consider that prompt in how/when/where it will add details.
As you see the result is nothing like the original image and it could be some kind of illustration in some SciFi story.
Next I’ve exactly the same rocket but instead of using the existing landscape and rocky bottom I let KS AI Shots create it. This gave me the following result:
Pretty cool, and I added a steampunk keyword so the materials of the rocket got a bit pushed in that direction.
Above again the 4x upscaled version of the area and you see the details are actually sharper and more visible than in the original.
Time for some extra AI using GigaPixel with the following result:
While there are obviously some issues with the depth of field which was in the input picture it’s really cool what it has done to the rocket, the rocky sand and the background.
As Maura wrote, if you put experiments here, they don’t have to be final artwork. When I saw Dries and Jan playing around with the AI Shots features, I got really enthusiastic about trying things myself.
With this experiment I used the upscaling of GigaPixel Pro AI and must say I was pretty amazed how the final images looked compared to the original material with terrible materials. You could do exactly the same as GigaPixel using locally running AI.
None of the images went through Photoshop etc.
